Buffettphan wrote:
Thank you all for the solid tips on my first post regarding roof systems. Helps a lot. All the campers I have had in the past I think I have spent more time on the roof applying sealant than I have actual camping. But not leaks, as far as I know.
So now another question. Slide out mechanics???? I am guessing there are a few different ones out there and I am guessing that some are better than others. I recently viewed a 2017 gaser with a large full wall slide. It has cables pulling it in and out and Teflon rollers underneath. Not knowing anything about slides I wondered if this was a good thing or not so good thing.
Once again, thank you in advance and I look forward to the input.
All my other rigs were straight models with no slides.
Carl
IMO, full wall slides are a no, no and cable drives, also. In fact any that require more than one motor, I try and avoid. POWERGEAR electrics are my choice and really don't see the need for hydraulic drives. I like them easily released for cranking them in and out manually, as well.
