rgatijnet1 wrote:
You should have vertical pieces of wood on each side and horizontal pieces of wood where each drawer is. It would not cause any problem removing the horizontal pieces but I would leave the vertical pieces to make sure that the top of the cabinet is properly supported. Attache your door hinges to the side vertical piece of wood.
Yes, that's what I meant. I want to remove the horizontal pieces. The rest of the cabinetry will remain intact. It just seems easier to have a little wooden door made than to hunt down a place that sells the right drawer pieces.
Thanks, Kay
