nandj's avatar
nandj
Thread Too Short on Inner Tire Valve Stem
I recently bought a small class C. It's on a Ford Transit chassis. It's the first vehicle I've had with dual tires. Both the inner and outer valve stems are quite accessible. This makes me think they are set up with dually valve stems.
The problem is on the inner valve stem. The length of thread showing is half what I'd expect. I can't connect to it properly with a gauge. There is a nut on the stem that presses against a flat rubber piece. The nut covers half the valve stem threading. I want to see if someone can tell me if the setup is wrong where I need to have someone look at it, or if I just need a different style tool to check tire pressure and to fill it.
I'll try to attach a picture here.
Click For Full-Size Image.
Thanks,
Neil
