n4hwl's avatar
n4hwl
Tiffin Electric window question
I have an electric operated drivers window on my 2014 Tiffin Zephyr. Does anyone know if the electric opening and closing mechanism/screw or whatever can be lubricated? It is working fine but lots of things work fine till they quit because they are not maintained.
Thanks
Ken
1 Reply
  • Yes, there is a spring that glides inside the tube. You can try and inject WD 40 or similar inside. Tiffin has used that system for over 10 years and I have never had to lube it or had a customer have a problem with that part of the mechanism. Do NOT install any screws at the forward mount. It looks like Tiffin forgot to install screws there but if you do, the mechanism will then bind and not work correctly. They leave that screw out on purpose. Doug
