timmac's avatar
timmac
Time for New Floors, Anyone with Pics of New Wood Floors
Its time for me to rip out the carpet and vinyl and replace flooring with water proof laminate wood flooring, would like to see pics of your new flooring to give me ideas..
I have cherry wood cabinets and walls, just cant figure the best color to go with.
:C
  • Bill.Satellite wrote:
    Carpet is NOT the enemy. Sometimes carpet makes sense. Hardwood/vinyl pretending to be hardwood in the bedroom is NOT for me. Carpet is warm. Hardwood/Vinyl is cold. Where and when you travel should be a consideration.
    X2
    I have personally put down 1000s of sq feet of laminate
    To me it it is garbage. Looks pretty in a picture though
    I’ll take carpet in the bedroom and living area and tile in kit and bath.
  • Carpet is NOT the enemy. Sometimes carpet makes sense. Hardwood/vinyl pretending to be hardwood in the bedroom is NOT for me. Carpet is warm. Hardwood/Vinyl is cold. Where and when you travel should be a consideration.
  • ScottG wrote:
    Does the slide leave a heavy mark in the current carpet? If so then it may also hit the vinyl.
    Yes it does leave a mark but not heavy, the carpet/pad is about 3 to 4 times thicker than the laminate flooring I am going to put down, I guess when I remove the carpet I will test with a piece of laminate to see what it does.
  • Luxury Vinyl Plank Flooring. Removed the glued down tiles and all carpeting. Replaced bedroom and front cab area with new carpeting. The vinyl is thinner than the carpeting so no real issues. I did not do the slideout carpeting. or under the slideout.
  • Does the slide leave a heavy mark in the current carpet? If so then it may also hit the vinyl.
  • I also heard slidouts can scratch the laminate flooring, the laminate I am looking at is thinner than the carpet/pad, would this be a issue.
