Dale.Traveling wrote:
Before throwing out what you have if possible check the tire sensor battery volts. Low power may cause inaccurate data and communications drop outs.
If your determined to replace the system I've had a TST Model 507 for the past 8 years and it's been pretty reliable. Cold pressures are normally the same as my hand held gauge but I have seen some deviation from time to time. Not more than about 2 psi which is close enough for my use. Any sensor drops have been low battery volts which is a five minute fix.
Yeah, probably a good idea. Batteries are about a year old. For 6 it's less than $20 so maybe I'll do that first.
Al
