locster's avatar
locster
Tire pressure fluctuation when hot
Via my tire pressure monitor kit, I noticed that my tire pressures in all 6 tires increased uniformly by as much as 18psi from cold pressure on a long trip thru the desert. Is this normal?
I drive a 21ft Coachman with just normal full weight loading. I typically set the tires at 68psi in the front and 75psi in the rear.
