diplomatdon
Nov 09, 2015Explorer
Jeff, I would suggest you weigh the front axle, then go by the inflation recommendations on the side of the tire. You are better to run at the max rather then min as the tires will run cooler, as heat build up due to a lot of flexing is not a good thing. Remember the Ford Explorer/Firestone problems of 10+ years ago was from Ford telling the owners to run them lower to get a smoother ride. Don't believe the coach manufacturer, trust the tire manufacturer. Don
38,766 PostsLatest Activity: Jan 10, 2026
