vandave's avatar
vandave
Tire pressures and axle weight
Purchased ourf first class A, 2017 Winnebago 31BE, and are starting to get it ready for at our trip south. Once loaded, I will have it weighed to ensure front and rear axles have weight distributed somewhat evenly and that I am not exceeding max. Total weight. I've towed several different RVs but never used a Class A before. I am concerned about correct tire pressures and have scouted the web for information and am a little uncertain what amount of air in each tire. My travel trailer tires were always inflated up to about 80lbs. As I understand it, there is no reason to inflate Class tires to about the maximum. I think my 19.5 tire max is 129 lb and most are putting 85 to 90 lbs in their class A. Also, it has been posted several places to put the tire pressures based on chart that calculates proper pressure to axle weight. Where does one find such a chart? And it has been recommended to have each axle tire weighed individually. How is that done? Going through a truck stop I can get total weight and front and rear axle weight but not each tire weighed separately. At 70,there's always more to learn. Help me out if you will. Thanks.
