TominTampa's avatar
TominTampa
Toilet Flange Question
Hello All,
I’m replacing the toilet in the Monaco, (and a large chuck of subfloor) and have a question concerning the flange and the mounting surface. Apparently the black water tank’s pipe is slightly tilted to one side, therefore when bolting the flange to my perfectly level surface, the flange contacts one side tight, and the other side has about a 3/16” gap. Using common building shims I can easily shim the high side so that I’ve got a good solid surface to screw into the floor through, but is that going to be a showstopper? Or will the doughnut gasket compensate? Any thoughts? - Tom
