Rwake901
Nov 04, 2014Explorer
Toilet Removal
The bowl has come loose from the base of the toilet in my motorhome. The bowl is porcelain and the base (with the flush valve) is plastic. Looks like I will have to remove the toilet and turn it over ...
Rwake901 wrote:
The bowl has come loose from the base of the toilet in my motorhome. The bowl is porcelain and the base (with the flush valve) is plastic. Looks like I will have to remove the toilet and turn it over to see if it can be tightened. My question is of those that have had their toilet off is there a wax ring like the toilet in your house that I will need to replace or how is it sealed? Thanks Roy
