jeromep
Aug 27, 2020Explorer II
Matt_Colie wrote:
Jeromep,
If it just looks old, well, it is old. So is the rest of the RV. If you want it to look new, get so plastic cleaner and go at it. If you want it to look newer, wax it.
The box under the pot is usually because they had to make more room for the black tank, so there is not much you can do about that.
Matt
I see the GMC motorhome in your sigline. I would have purchased one of those GMC motorhomes in a heartbeat, but I kind of needed a (mostly) turnkey vehicle. Plus, in my area they are kind of hard to find, especially ready to roll.
I've been looking under the floor and have really great access and clear shot of the black tank from the basement and service hatch, I'm not really seeing the black tank go up into the house through the floor. I see a riser pipe where I suspect the toilet is located, so I'm kind of assuming that it is just a riser pipe through the floor, shrouded by the box and to the toilet.
Thanks for the suggestions. It's about all I can do, for now.
38,780 PostsLatest Activity: Nov 24, 2017
