I have a question for all of you who had minor toilet seal problems. My toilet seal is leaking water at a very slow rate. Even though it won't hold freshwater inside the bowl there is absolutely no fo...
TRY first drying the bowl and seal,then coat the seal with vaseline and work the peddle back and forth,then put some water in bowl and see if it holds water.
