Mondooker's avatar
Mondooker
Explorer II
Jan 24, 2016
Top of line Gasser Vs. bottom of line Diesel Pusher
Since joining the forum I've asked a lot of questions and received great answers. And when asking questions about something new, other questions come up.
One recommendation I received was buying a newer model Gasser instead of an older model DP. This is my first motorhome and I want something around 40 feet and want to spend no more than $100,000.00.
As I'm looking at used upper model Gassers, which i'd not done before, like Tiffin Allegro and Newmar Canyon Star. I found that the base models of Diesel Pushers are around the same price.
My question is "what's a better move for a new-be, a top of the line used Gasser or the used base model Diesel Pusher"?
Your help has been invaluable, thanks you!
  • There are some really mid 2000s diesels available in the $100K range but the maintenance is more expensive. And there is the catastrophe case, where you need an engine or something.. A new v10 is about $10K. A new diesel might be $18-25K or more. It cost me $13K to fix a catastrophic head disaster in a Cummins about 5 years ago. And I watched the work, no ripoff.
    If you can afford a catastrophe, I would go the diesel as the ride and components are much better quality.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Not many gassers over 37' as that's about the max weight for a V10. That said there was a recent post about a 40' Tow Hauler that even had a decent amount of CCC partly because of the empty space in the rear.
    "Diesels can get very expensive for both Maintenance and Operation"... I have not found that to be true, but I do all of my own M and O plus repairs. I would go back as many years as necessary to find a mid level DP.
    It will be interesting to see how much this no reserve .......Monaco Signature goes for... my educated guess $115K for a 03 top of the line maxed out DP.
    PS: you will not find a bath and a half in a gasser.:B
  • Everyone has an opinion so here's mine. The $100K DP will be a much better coach than the new gasser for close to the same price. Better built from the frame up and better built in the coach too.
  • First rig!
    I would suggest something smaller in a gas rig. Somewhere around 35 foot.
    Diesels can get very expensive for both maintenance and operation.
  • If it were me looking with a 100k budget I would do the DP. You can get a real nice used unit for that kind of $$$. I purchased our 2000 Ultimate Freedom from Winnebago for 55k when I got it.
