Sabretooth's avatar
Sabretooth
Topping up Engine Oil ?
Ok checking my engine oil today, I needed to add 1/2 qt. The only way I could do this was by lifting the bed and topping it up via the filler cap ?
Then I have to close the bed, start the engine and recheck the oil level outside. Luckily I put the right amount in the first time. But is there any way you can top off the oil via the dip stick tube? Or a modification I can do to stop the laborious task of in and out and raising the bed?
I can top off the transmission via the dip stick. which is a lot easier.
My coach is a 1992 Gulf Stream DP with a 5.9 Cummins and the radiator transmission cooler are at the back so vision of the engine is restricted.
Appreciate any advise from others whom have over come the problem.
Thank you
