ArchHoagland wrote:
mowermech wrote:
It occurs to me to wonder: Can the Lincoln MKX be towed on a dolly?
If it is front wheel drive, probably yes.
If it is AWD, probably no, unless the rear driveshaft is disconnected.
If it is rear wheel drive, quite possibly no, unless the driveshaft is disconnected.
OP, you need to read the Owners Manual to find out!
Good luck.
That's what I was wondering too. Could look it up on Remco but there is no year stated for the Lincoln.
I have noticed in the past that REMCO was not correct on their towing information. You have to look in the car owner's manual.
Our 2017 Lincoln MKX is an AWD model. There is a detailed procedure to follow for set-up. We have a push-button transmission that needs to be put into 'neutral tow' for towing. So far, no problems as we've towed it about 3,000 miles.
Motorhome magazine offers their towing guides on line. You can pick the 'year' guide that you need from the list.
Safe travels,
MM.
