jhilley wrote:
The problem is in the ground side of the magnetic tow lights. Take them apart and check for a borken wire to the ground side of the lamp (the base). Could also be caused by corrosion. Check all connections and clean the sockets.
TexasH wrote:
Tinyandthegang wrote:
The problem is not in your coach but in the ground to the toad lighting.
Check the ground wire at the plug to the coach. All the symptoms point to a bad ground on your magnetic lights. Also, you might check by rigging a separate ground wire from the ground wire on your tow lights directly to coach chassis. I would spice in a test wire near the lights themselves and run to the coach just to eliminate an internal break in the wire. The wiring on those magnetic lights take a beating. Just some other suggestions to try....
I have a 2'd set of magnetic tow lights; that give the same problems. Doesn’t seem likely it’s the light wiring. Maybe it's the umbilical cord (it looks good, no cuts in insulation). I do drive washboard dirt roads for a couple miles most trips, lots of shaking and dust back there.
As suggested, I'll try a separate ground wire, directly from the lights to the coach chassis frame - but can't get to it until next weekend. Thanks for the suggestions. I'll give an update in a week or so.
