- rooster2ExplorerWe pull a 2011 AWD Terrain with a DP. Easier than old 4-Runner tow with Remco drive shaft disconnect. Pull Terrain in neutral and pull 1 fuse turn key to where steering wheel will turn. V10 should pull it okay, but would go with tow specs. for your RV.
- bsinmichExplorer
dpmotorhome wrote:
thanks all
am towing the terrain with no problems except I suck wind over 60000 feet of elevation
You really do fly high!! Most commercial planes stay less than 40,000 feet. - dpmotorhomeExplorerthanks all
am towing the terrain with no problems except I suck wind over 60000 feet of elevation - chucl66ExplorerBe sure to check the capacity of the hitch. I have the same chassis. 36 ft., my hitch is only rated for 3500 lb.
Chuck - donhoward49ExplorerSo I goggled GMC Terrain weight, they say around 4000 LBS. Thats good. Then I went to Romco RV Towing. They say it can be towed with speed and distance restrictions, see owners manual... Try remco for good information.
- Mike_M2ExplorerA terrain is a pretty small SUV, it'll pull it and you won't even know it's there. I've pulled 4 times that wieght with my F53 chassis V10...
- Ka_RonExplorerFord will pull a Chevy any day!!
Is the Terrain towable 4 wheels down?
38,766 PostsLatest Activity: Jan 10, 2026
