Snomas's avatar
Snomas
TPMS sensor failed
Took my MH out of storage the other day and the tires all checked OK on the TPMS monitor. Got home and 2 hrs later I drove off to put it back in storage and a low tire warning went off. My pass side inside rear dual read 82 psi. I took it to a truck stop and they pulled the tire and found it was ok. After re-installing the tire we put the sensor on and found it was leaking. $43 and it was the sensor!! Never had a problem w/tires before in 14 years of Motorhoming. I know the TPMS system is an important safety item!!! Just venting!
  • As said anything mechanical can have problems.
    I checked tire pressures on a utility trailer the night before a trip. The next morning one of the tires was flat. I had a defective valve stem core.
    So without a TPMS and checking pressures each morning can also get you into trouble if a valve stem core fails to reseat after the pressure check.
    I suspect in the OP's case the sensor was not on tight enough.
    When I first started with my TPMS system I found you have to put the sensors on pretty tight.
  • That's why you need to have the Doran System. Ther are the first and best. They have metal sleeves and seals and do not leak like the others with rubber seals.
  • My take is a little different in that the system worked correctly in that it alerted you. Now that fact the problem was the sensor is a bummer. However, I have had valve stems to start leaking. Anything mechanical fails.
  • The brand is Tire Tracker and I purchased them 2 months ago and installed them in Sedona and then drove home to Denver w/no problems. They are sending me a new sensor. I like the lubrication method John Wayne is using! Why would 2 month old sensor have an o-ring problem when it was working 2 hrs earlier and I had only driven about 12 miles?
  • On my sensors When I first get them I take an old valve stem and put a SMALL dab of anti-seeze on the lip of the stem. Tighten sensor on to the old valve stem to lube the o ring and no more problems of torn o rings from dry valve stems.
  • That's one reason I added the Duallyvalves.
    TST sent me extra O-rings with the tst system.
  • It happens. Windex and Simple Green are great bubble makers. If you had one there might be more. If the sensors are a Trucking System Technology product they will send you a bunch of replacement o-rings for free. Not hard to replace.
  • Inside each sensor is a small "O" ring that should be replaced from time to time. I have the TST system and I replace mine when I replace the battery.
    Not to rag on the OP, but a simple "spit" test on the valve stem would have saved you the $43 bucks....my dad always preached to us kids....SWSS...Start with the Simple Stuff.....
    Be glad you didn't have to buy a new tire, so in the scheme of things, you still got a bargain..if that makes you feel any better.....:).....Dennis
  • I'm about to buy a TPMS for my rig.
    I'm just wondering what brand name your system is?
    How old are the sensors?
