paullac
May 16, 2015Explorer
TPMS, Valve Stems, & Wheel Covers
Faulty leaking valve extenders on our Sunseeker have short circuited a trip each year now. So I'm planning to remove them altogether & replace with a TPMS. I'm leaning toward the TST 507 based upon what I've read on various RV forums (or one by Tire-Safeguard as it's ranked higher than the TST on Amazon).
Two questions:
- Can I, in fact, remove the valve extenders? I'd replace the valve stem with metal ones but it would just be the standard shorter length ones. I'd then install the TPMS directly on the valve stems. I'm thinking specifically about the inner wheels on the back. I know when I needed air on the inner wheels I'd have to contort my body some. I'm just trying to avoid another $150 for the Tire Man type longer metal valve stem / extenders.
- Also, do the flow through sensors "fit" on the valve stems with the simulated wheel covers still installed? I had read somewhere that because the flow through sensors are bigger they interfere with the simulated wheel covers.
Thanks in advance!
Two questions:
Thanks in advance!
