dons2346
Jan 29, 2015Explorer
First thing is you should not use the dipstick to check transmission oil level.
You should use the trans shift pad to check the level. I suggest you read your manual on the correct procedure, you will be better off.
38,758 PostsLatest Activity: Nov 06, 2025
