pusherpilot
Jan 29, 2015Explorer
Mr.Mark wrote:
Holstein13, I'm going to check our transmission on Sunday after we get to our destination as the transmission will be all warmed up. I'll use the touch pad to verify if we're good or not. Our coach was completely serviced on delivery as it had almost 3,200 miles on it.
Thanks for telling your story.
MM.
Make sure the coach is level and wait for the oil level to count down for several minutes. There is a site, http://www.irv2.com/forums/f125/ where you can get advice from the retired Alison fluids engineer who wrote the spec for Transynd. He now has a fluids analysis company. I send him a sample of the Transynd and get an analysis back. I do not change the fluid on time/mileage . I do it based on contamination of the fluid. Many OTR and construction companies are saving lot of bucks by changing fluids based on analysis.
Ron
38,758 PostsLatest Activity: Nov 06, 2025
