Mike_Hohnstein
Jan 30, 2015Explorer
dons2346 wrote:
First thing is you should not use the dipstick to check transmission oil level.
You should use the trans shift pad to check the level. I suggest you read your manual on the correct procedure, you will be better off.
Very interesting point of view. Trust an electrical sensor, that could be inaccurate over a mechanical scale. Being in the heavy duty transmission business, I like the dip stick method just fine.
38,758 PostsLatest Activity: Nov 06, 2025
