holstein13
Jan 30, 2015Explorer
JR45 wrote:Good grief, those codes are so 2013. My transmission keypad simply tells me how many quarts high or low I am in plain English. No codes anymore. The keypad has a high resolution LED readout. That's progress for you. When I read the manual, I figured out how to use the keypad and that's how I verified the level.
Checking Fluid Level with the Keypad
The following procedure will allow you to check your transmission fluid level from inside the vehicle, and it is also more accurate than checking via the dipstick....
To exit the oil level display mode, press the NEUTRAL button or simultaneously press the UP and DOWN arrows twice.
JR
38,758 PostsLatest Activity: Nov 06, 2025
