Just discovered a leak were the turbo bolts to engine. Peice of gasket missing. I'm blowing black smoke under load and have a loss of power. Also looks like a nut is missing from stud on right side. I...
As far as integrity of the cooler I'd say you are good-to-go. Were you able to find any turbo blade piece/parts on the inlet? Since it is lightweight aluminum, maybe a good shop vac could pull something out if it's in there.
