Just discovered a leak were the turbo bolts to engine. Peice of gasket missing. I'm blowing black smoke under load and have a loss of power. Also looks like a nut is missing from stud on right side. I...
I'd say no pressure loss, good to go and one less issue and a very expensive issue if it had arose. Now, to see if there is any pieces parts in the bottom expansion chamber...
Look over all the connector hoses, especially on the pressure side and replace if necessary. Like I said before, a hose failure on the road could be a real issue.
