Just discovered a leak were the turbo bolts to engine. Peice of gasket missing. I'm blowing black smoke under load and have a loss of power. Also looks like a nut is missing from stud on right side. I...
Removed bottom intake hose to air charger and nothing there Vacuumed and nothing.Hooked up my big shop vac using a 4x2 ferenco ran vac went into coach and put my hand over other pipe letting go nothing sucked into vac. I'm calling it good to go. Once parts come in put it back togeather. Took old turbo all apart may rebuild it.
