wildmanbaker
Dec 25, 2015Explorer
KevinE wrote:
UPDATE: The harness leading to the turn signal was buried in the foam insulation in the corner. Once I dug through it, I found the connector was loose. Cleaned it up and reconnected it and secured the wire, problem solved. I think after it was on for a little, the ground heated up and started looking for a better ground somewhere. Thanks for the advise!
Good so hear that you got the problem solved, with good advice. Interment problems are very hard to find and solve. Thanks for getting back about the answer.
