timmac
Feb 15, 2016Explorer
barmcd wrote:45Ricochet wrote:
Wow that one ranks right up there in the stupid people list.
And if that breaks loose some innocent person could be harmed.
I guess they don't teach common sense nowadays.
I don't think this is a lack of common sense as much as it is ignorance of towing and physics.
I remember a group of people in Florida who were swinging themselves off bridges with a steel cable. One of their jumps resulted in a broken cable, one death and several injuries. Turns out they didn't understand physics. They made sure the cable would support their weight, but didn't understand how their weight was multiplied through the swing of the cable.
Brian in Michigan wrote:
Timmac, how do you get your boat down? The boat weights nothing but the outboard is another story.
Ivylog wrote:
TimMac, I would double up the channel on the outside of the hitch V up to your step plate. Does not look like a trailer designed as a car hauler... lots of up force on the tongue when load/unloading the Jeep. I like the T iron you added to the sides of the trailer. I would NOT have run the two front pipes to the outside of the trailer... a couple feet in would stop the top from rocking side to side. How does the winch lower the boat down... I do not see any pulleys.
PS: I did sleep at a Holiday Inn recently.:B
