lj2654's avatar
lj2654
Update on RV repair issues!
Well here is an update on my repairs. Coach( 2001 Beaver with a CAT 3126B diesel) in CAT service center last day of August. Having minor issues taken care of. I did tell them they could take their time on it but I had to have it back by November 1st the very latest.
All I was planning to have done was:
serpentine belt
water pump belt
look dash a/c system and see what it will take to fix
thermostats(2) replace
items found during inspection:
rear wheel seals leaking - need replacing
engine fan blade cracked - needs replacing
a/c compressor bad - needs replacing
a/c servicing port leaks (2) high and low - replace
a/c low side hose leak - replace section of hose
Items replaced:
rear wheel seals
serpentine belt
water pump belt
a/c compressor
a/c receiver dryer
(2) engine thermostats
a/c service ports(2)
section of a/c low side hose
engine fan assembly( I ordered and took to them! (they couldn't locate one)
These items were all replaced but not done until November 18th. Delay after delay.
Shop Foreman took coach for test run...18th...overheated right away(225)
Told it was a radiator issue! Started to remove radiator and found insulation debris forward of radiator from engine area that had fallen....took it out and he stated 95% sure the problem....reinstalled the loose radiator, test drove again. Now runs at 217 degrees(still too hot! Wants to do further checks....now ran at 200 degrees prior to thanksgiving. The Monday after he drives again and now 217 and hot! Now they pulled out radiator, CAC, and removed the thermostats again. Said the radiator needs to go to shop, clogged fins.
Radiator shop pressure checked it 12-4...its not clogged up and ok, not the cause of overheat issue. Going to clean it and also I took the CAC and he is cleaning and leak checking that too. Should be ready 12-8 or 12-9!
The CAT shop is going to test the thermostats for proper opening visually now...after me asking that question after the first 225 condition. Been out twice since!
Had to cancel Thanksgiving trip. Now have a trip for December 19th-29th We will more than likely have to cancel.
They don't have access to 50 amp service for battery charging they just told me two days ago, so batteries have been charged each time enough to start engine.....so I went and bought an adapter so they can leave coach plugged in to charge them.
A new service manager has just started there and this is the first big issue .....I had heard good things about their service, but now I see a lack of communication, poor scheduling issues, and lack of concern for completion in a reasonable time.
They still don't know what the overheat issue is as it didn't have one prior to going there. I have driven the coach over 11000 miles in four years with no issues.
It may be AG complaint and attorney time very soon!
  • the fan seems to be the common denominator. if this is a rear rad or a side rad if it is a rear rad remember the engine sits backward from a truck chassis the natural air flow is from front to back so the fan should push the air from front to back the opposite that it would in a truck chassis may be worth checking
  • Wow!! Man, They are raking you over the coals. You need an advocate now. Stop messing with them and get the attorney. They are training the whole place on your coach and your nickel. I don't agree that some of those low 200 degree temps. indicate overheating either.
  • I would suggest that if the coolant temperature rises above thermostatically controlled temperature except under harsh conditions (long grades, high ambient temperatures, etc) that you DO have a problem.
    As already suggested, with fan replacement, the most likely suspect is a fan installed backwards. Easy to do.
    The fan sucks from the front and pushes air out the back. If installed backwards, air flow will be severely limited causing overheating under even mild conditions. START THERE!
  • Physically look at the fan. As mentioned above. I had mine replaced in Winslow AZ at a reputable and professional shop and they put it on backwards. It never over heated before and after the fan installation it just ran too hot. I compared the shape of the blades to another DP and found it backwards. The original garage paid to have it turned around. I'd bet good money that is your problem.
  • 3126/c7 engines don't normally have a problem with air pockets normal fan on temp is around 200 to 205 so 217 is getting close to logging a over heat code and a check engine light in defense of the mechanic , if the fan is on backward he is first and foremost a truck tech but he should have been more careful if the old fan is still available double check it some pusher fans are different than just flipping pull fan around
  • Does it have a hydraulic fan? Did someone hook up the hoses wrong? Is the fan operating? Usually the control valve for the hydraulic fan has a wire on it if pulled off will allow the fan to run all of the time. So if it isn't running when it gets to fan on temperature..you could pull the wire and see if it corrects the heat issue. Just my 2 cents..
