hotjag1
Feb 03, 2015Explorer II
Update:::Unidentified Electrical part on Allegro Bus
This part was bolted onto the left rear frame rail beside the transmission. It has a 6 gauge cable(wire) attached to the battery side, and a smaller wire(16gauge)attached to the aux side. Both terminals were corroded, so I was removing the nuts so that I could clean them, but the threaded stud on the battery side started to turn and cracked the housing.
Does anyone know what this part is? I've been told by the RV places that it is either an isolator, relay, or some sort of circuit breaker.
It is on a Freightliner chassis. I called Tiffin, but their tech was busy and I did not leave a voicemail. I'm hoping someone on here recognizes this part or replaced it. I don't know if it is Tiffin or Freightliner
Thanks for any help on this.
