BruceMc's avatar
BruceMc
Explorer III
Aug 27, 2016
USB port/Power port project
It was interesting that GM supplied two power ports and even a 110VAC port (while the engine is running) in the dash, plus lots of other locations for accessories.  We found the power port on the right was in the way of the passenger when exiting the seat if a usb adapter was plugged in.
Not having any built in usb ports, I searched and found some ports that were designed for boat use - but very serviceable for RV use as well.  I purchased one in red and two with a small blue light with the intent of putting the red one in the dash, and the blue ones elsewhere but decided I wanted 4 ports up front.  I may get another red one and replace the blue.
While driving at night, blue is the worst color to have on or around the dash.
Note that usb ports have a parasitic draw, so if you want your chassis battery to be run flat, these need a shutoff switch.
Here's the completed project with all ports closed and power off:
And the setup powered on and the port covers opened:
The factory power plug was in the extreme right position; I moved it to the left one spot and installed the red usb port in that location.  I also moved the 110VAC plug to the left one position, and installed a second 1" RAM mount ball so my wife or our friend can install their DeLorme mount as I have on the left side.   The switch shuts down power to both usb ports, but both factory power ports are constantly alive.  I chose a switch with a red LED indicator as both usb port covers complete hide the indicator lights.
Another project complete!
  • I have them all over my trailer. I recently installed on/off switches as they do draw about .1a when not being used. Great addition to my trailer
  • They do draw a parasitic load, but I'm not sure how much. Very small, no doubt.
  • I have three of those installed in my 5th wheel and never had a battery drain problem. They are always on.
