Here's the OP's original question. With all the side spats I'm sure he's moved on by now but just in case.
tres perros wrote:
Hello folks
I have been looking for a used class A leaning towards a diesel as I plan on towing a Jeep and travel west coast, rockies
Evidentially I am told that the newer V10 fords have very similar torque range ( a model change with an extra valve)
So Id love to hear some opinions regarding this, including if maintenance/warranty contracts are any cheaper...
Thanks ahead of time! This is a great forum and has been very helpful
Keith
Yes, maintenance contracts and overall maintenance will be cheaper but given your intended use I'd go diesel.
Reasons.
1. Generally heavier construction, including more towing capacity and CCC
2. Ride, can't beat air bags, and depending on the model even a 36' rig the only way you can tell a truck went by the other direction at 60mph on a 2 lane road is by watching it.
3. Engine noise is in the back, you can hold a conversation at normal levels going up an 8% grade while towing 6500lbs of Jeep and trailer.
4. Turbo diesels put out rated power up to 10,000'. Folks seem to like to toss around formulas, here's another one.
HP Loss = (elevation x 0.03 x horsepower @ sea level)/1000
A ways back after another thread like this I went to
THIS website and did some calculations. Based on the latest and greatest 362HP Ford engine, if you go back to the more affordable 310HP engine (pre '05?) it gets correspondingly lower results.
Starting with 362hp ****** 350 hp turbo diesel
0000' 362.0 hp ************ 350 hp
1000' 351.1 hp ************ 350 hp
2000' 340.3 hp ************ 350 hp
3000' 329.4 hp ************ 350 hp
4000' 318.6 hp ************ 350 hp
5000' 307.7 hp ************ 350 hp
6000' 296.8 hp ************ 350 hp
7000' 286.0 hp ************ 350 hp
8000' 275.1 hp ************ 350 hp
9000' 264.3 hp ************ 350 hp
10000' 253.4 hp ************ 350 hp
Now the Diesel coach will weigh more, ours with 100gal fuel and 100gal water with stuff to camp for 4-7 days comes in at 25,300lbs and still has 2700lbs of CCC available.
For us the ride, quiet, CCC and towing capacity made it no contest. Believe me, I'm a cheap SOB, I tried to make a much cheaper (or newer/nicer) gas unit work but it just didn't pencil out as we spend all our time in the OP's target area.
