Mr_Mark1
Dec 09, 2014Explorer
Yes, the clicking at start up lasted about 15-20 seconds. It would do something like a double click towards the front of the coach, a double click coming from the middle and another double click from the rear. Then it would stop and I would start the coach.
It's sounds like your leveling system takes a little longer than ours to level. If you are thinking of buying this coach, I would have it checked out by a trusted tech. The leveling system can be reset (zero'd out) and the procedure can be downloaded from the Valid site. It does say that it's best done by a tech (if I remember correctly).
Also, you can call Monaco with the VIN number and they can tell you if it's normal or not.
MM.
MM.
38,782 PostsLatest Activity: Sep 10, 2026
