chuckftboy wrote:
Most of the heat in the basement is from heat from the engine and exhaust on a front engine coach. You would need to dump a lot of a/c down there to get any benifit of cooling. Any air that leaves the inside and is dumped below will be replaced from ooutside through leakage around slides, vents and windows. It would make more sence to just put the drinks in a cooler with a 2 dollar bag of ice.
Yes that is something I considered. Because when you put on the bath vent you feel the air coming in from other outside areas. At first i may try to insulate the compartments.
