ander wrote:
Hi all
Im in the process of adding a solar panel to my 94 pleasure way...ive read that 3m vhb tape works but there are a number of numbers... for those who have done this. What tape did you use.
Thanks
3M VHB is 3M's "Very High Bond" double sided bonding tape which is a very high strength tape that when applied correctly is a proven alternative to rivets, welding and other fasteners such as screws and bolts that results in a very strong and permanent joint. I have used the product for a number of years with great success. It is used extensively in the building industry and by aircraft manufacturers to yes, hold commercial jetliners together instead of using rivets at times. Most, but not all the different numbers are due to different widths of tape, different colors (of center foam) and most useful, different thickness of the center foam. If the surfaces you are adhering together are VERY level, then you can use a very thin tape, but if the surface is not totally level when you want to use a thicker tape which has a thicker center core. An example of this are the numbers and letters attached to the sides and rear of cars and trucks to distinguish different models. Those model numbers are glued on with a product like VHB. It is my understanding that AM Solar of Springfield Oregon has used 3M VHB to attach solar panels to class B's. You can purchase 3M VHB at Amazon and ebay in small amounts.
