Tracus wrote:
I'm using the LP for hot water. I tried switching the refrigerator (a Norcold) to LP, but got an "F" on the display panel. I assume that means there's a fault, so I've switched it back to the electric mode. The refrigerator is turned off when we drive and then we use the sites electricity to run it. The site is dead level fore and aft and port and starboard.
Thanks again,
Chris
The "F" fault code indicates the burner failed to light. Possibly air needs to be bleed from the system, try a couple of times prior to getting service.
Fred
