we have a 2006 Winnebago journey .I need to remove the monitor unit out of the dash. question is how do I start and what I have to remove thanks for the help rudi [email protected]
With my Voyager monitor there is a trim piece that is removed around the edge. It is about a 1" frame around the entire monitor and it just snaps on. Once it is removed you will see the "push" place that you can push on to release the monitor and allow it to be pulled out, leaving the support frame in place. This will allow you to get to all of the wiring on the back of the monitor. If you want to remove the support frame, you can now get at all of the screws.
