s N s wrote:
wolfe10 wrote:
OK, what can you move FORWARD!
X 1 I totally agree with the above post.
Agree also. Moving weight forward will help with steering caster angle which should improve your directional stability. Try that first, then change your tire pressures, (also check for irregular tire wear) then, if no help, have your alignment checked/adjusted. Make sure everything is adjusted properly before you start installing band aids.
Start with the attitude: "When everything is loaded correctly, the tire pressures are correct, and, the alignment is correct, the vehicle will drive/ride properly." Not: "Let's throw some parts at this problem." (unless you have obvious wear issues or bent/damaged parts)
Chum lee
