Cass_Sumrall's avatar
Cass_Sumrall
Water drip from AC return
Our 2 yr old 2013 Itasca Sunstar 30T has recently developed a water drip from the AC return. It only occurs while traveling at highway speed with the AC running, not while stationary.
Has anyone encountered this issue?
Thanks,
Cass
  • Thunder Mountain wrote:
    Two things to check. Pull the A/C cover and make sure the drain holes are not plugged and pull the inside plastic cover and check tightness of the four hold down bolts. Since it happens at speed and not stationary I would suspect the bolts.
    X2 Drain holes.
  • sch911 wrote:
    What do you mean by "AC return"?
    Are you talking about the chassis or Roof unit?
    It is the roof unit for the coach & the return is where the filter is located in the ceiling.
  • Two things to check. Pull the A/C cover and make sure the drain holes are not plugged and pull the inside plastic cover and check tightness of the four hold down bolts. Since it happens at speed and not stationary I would suspect the bolts.
  • What do you mean by "AC return"?
