TechWriter wrote:
Yep. One of these + tap it with a rubber mallet. It works with my Big Blues . . .
Don't want to deviate away from the OP question but I think the original question has been taken care of so, TechWriter, WOW!   I followed your link to take a look at your Blog to see if you expanded a bit on your fresh water system and I need to pick your brain a bit.  I am in the process of doing something similar with our coach and I want to specifically plan to plumb my softener into our fresh water system so I can still use the retractable hose.  My question, I cannot tell for sure but it appears that your retractable fresh water reel is still used to connect to a shore supply.  So, you must have connected into the outlet of the reel which on most is 1/2"NPT?   I'm not too sure what access I really have to that point without removing the reel on our coach which I may have to do.   So,any hints or tips there on how you did that?
