DANO2014 wrote:
I have a 2002 Allegro Bus with Cat 330 HP!
I am not having any problems "YET" both
engines running great, Cat & Generator ( Deisel)
. How often & where should you check for water?
Is there some kind of bleed-off valve around
Fuel Tank & Or Fuel Filter? Appreciate
any & all information on this!
Thanks,
You should have a fuel water separator on the chassis frame rail. It's clear with a tap on the bottom for draining the water off. You should have two filters up on the engine for fuel filtration. The ones on the engine should have been done every time you got an oil change, I do the fuel water separator every 15k miles.
