Kennyg
Mar 12, 2014Explorer
Leland2 wrote:rmasonschneider wrote:
give Vaseline a try and if that doesn't keep it sealed, time to change the rubber seals. But realize that most will leak water into the black tank over time...for mine, water will stay in the bowl about 10 days before either evaporating or draining to the black tank.
good luck
I'll try the vaseline.
For my 5ver, where water has never stayed in the bowel (draining in probably an hour or so), do you think the seal came defective from the factory? Guess I'll replace that seal too.
Revised: Googled this stuff and found out about the seal, removing the toilet, etc. Wow. I had no clue.
Just curious -- have others done this job? 12 year old Class C, a seal I've never cleaned, it's held up pretty well.
If you need to purchase the rubber gaskets, do so on-line! I needed rubber seal and went to local RV cener. They wanted $40. Went to camping world web site and purchased exact same for well under $20!!
