MustangGT
Jun 12, 2013Explorer
Gjac wrote:
12v NC water valve
I like your valve much better than the huge sprinkler valve from Orbit/Rainbird I was looking at. Ebay has many and low $$$ too.
So: valve ~$10
momentary swx/wire etc:~$15
nozzles ~$8
tubing/elbows/couplings etc: ~$15
filter (i have hard water): ~$14
total:~$62
I'll "t" off from my PEX fresh water tank line. that 80 gallons will provide TONS of cooling. I'll have to test this set-up first to determine if a dedicated 70psi pump (ebay) is needed for an efficient mist. I don't want a stream. I want a Mist. Just because.
Maybe swap in a REAL engine temp gauge with REAL numbers. DYK, would that be a straight swap from the OE "Normal" gauge?
thx for the ideas.
