Gt327ds's avatar
Gt327ds
Water pressure regulator
I just purchased a 2012 class a motorhome and was wondering if a 40 psi water regulator is required as in a travel trailer.
  • If you are talking about the small pressure reducers that you can buy at the RV store forget about it. Those things are nearly worthless.
    Do this instead. Go to Home Depot, Lowes or whoever is near you and buy the following parts:
    1 Watts N45BU pressure reducing valve, Home Depot P/N 111388,
    1 brass male hose to 3/4" pipe adapter, Home Depot P/N A665,
    1 brass female hose with a swivel to 3/4" female pipe adapter, Home Depot P/N A661,
    1 brass 3/4" close nipple, Home Depot P/N A877.
    These part numbers are about 10 years old so they may have changed since then but the parts are still there. Ask someone in the plumbing department if you're not sure what you're looking for.
    Put these together, attach a hose to both sides and you will not have to worry about water pressure again.
    This tip appeared on here several years ago. After going through I don't know how many of the cheesy little pressure regulators, which in fact are flow reducers, I put one of these together and have never worried about water pressure since and that was almost 10 years ago.
    The pressure reducing valve is the same type that is used on your home. You can adjust it for whatever is a safe pressure your particular RV.
    All of the parts will cost about $50 but it beats waking up to the sound of water flowing through your RV at 3 AM.
  • All58Parks wrote:
    teddyu wrote:
    Does anyone realize that a typical RV pressure regulator only works when there is flow through the line. At a static head (no flow) the RV pressure downstream of the regulator goes to the service line pressure until flow is established, then the pressure is reduced. I do not use one. My system is designed for the typical CG water pressure. When I check-in I always ask how their water pressure is. If they say high, I fill my tank and use the pump. JM2¢...
    Not quite accurate. A functioning PRV (Pressure Reducing Valve) will hold the maximum setting even with no flow. A valve with a dirty or worn valve seat will perform as you say. I use these all the time in my line of work, and have tested and serviced many over the years.
    I believe there is a distinction between the inline RV pressure regulating valves and the pressure reducing valve you described. The external spring in the PRV regulates the diaphram openning to maintain a set pressure. The internal spring of the typical RV pressure regulator acts more like an excess flow check valve than a pressure reducing valve. Big difference in functionality and cost. JM2¢...
  • Does anyone realize that a typical RV pressure regulator only works when there is flow through the line. At a static head (no flow) the RV pressure downstream of the regulator goes to the service line pressure until flow is established, then the pressure is reduced. I do not use one. My system is designed for the typical CG water pressure. When I check-in I always ask how their water pressure is. If they say high, I fill my tank and use the pump. JM2¢...
  • It's not the PRX tubing that fails or leaks...It's almost always a fitting, faucet or valve that lets go.
    I'd definitely use a water pressure reg. Ours is adjustable and set at a conservative 4psi...plenty of pressure for our use.
  • I have an adjustable regulator that I have set to 60 psi. Modern motorhomes are set up to run 60 for the most part. If you are in doubt, contact the tech department of the mfg or post the details of your coach so someone who has the same brand can be of help. I can speak for Tiffin and Southwind ('04) but have no idea about other manufacturer's specs.
  • The newer RVs can take higher pressure with Pex tubing but I still use a 45 lb regulator
