moon_lake's avatar
moon_lake
Water pump on and offf,,,
I have noticed that the water pump sporadically turns on and off when
no one is even using the water, and hasn't used it in days. Is this
normal? Or do I start looking for a leak under the rig?
Thanks.
  • The Pump will keep the pressure at a set point. I would only be concerned if it was cycling more than once a day. I know my will not cycle if no one uses water for a few days. If it cycles more than that I would start checking., it could even be leaking pass a check valve back to the tank. I am sure you will hear from others on where and what else to look for.
  • Normal! Yes, in most rigs this will happen. It could be a small leak. Most likely it could be leaking back through the pump.
    We normally turn the pump off when not in use.
