This may have been discussed at times earlier, but I don't know when it was. We were in Fl. over the winter and some of the campgrounds that we were in had no wifi unless you went to the rec room or...
I have good luck with something like this for less than $40. Much the same as the Bear above plus you get the yagi antenna. Does not need to be mounted outside and it lets you sit in the car at McDonald and snag their signal.
