Mr.Mark wrote:
Mile High, I also had never heard of weep holes in the slide out room. Learn something everyday!
How long is the drain pipe for the weep hole? It's not the whole height of the slide is it? I can't tell much from the pictures.
Safe travels,
MM.
They are only an inch or so - they drain the well the slide lock sits in above that black plastic cover. The drain more or less takes the water out the side and then straight out through the wall.
There were a lot of things my Dealer didn't mention, but he sure talked about those weep holes :)
