wny_pat1
Dec 17, 2013Explorer
wildmanbaker wrote:I think the big worry is the engine's many computer and related components, and not the engine itself. Things like the cpu and even the dash cluster.
RayChez,
When I started working in a auto shop, at age 17, I also heard the welding on, or around an engine would completely ruin an engine, by welding the rod, main, cam bearing to the crack and cam. Well.....Guess what, there has not been any engine ruined by welding on the block, head, intake, or exhaust. I would imagine that if you placed the ground on the crank snout and tried to weld the block, you might have a problem, but I doubt it, as everything is oil coated. Electricity is like water, it is lazy. It will take the path of least resistance.
38,773 PostsLatest Activity: Apr 23, 2026
