6ofus wrote:
kerrlakeRoo wrote:
As to the Generator, all newer units have generators with a remote start capability, usually both on the van dash and in the coach. They are not normally set up to "automatically" start when outside power is off or it would be trying to run every time you were storing or driving it.
So I guess my question should be, is there something out there that would give a unit this option if it did not have it to begin with? Or is there an app that would tell me if we lost power? Worried about the dog.
I would think so, Back up home generators have an additional control that specifically monitors power and automatically starts a unit.
I wouldn't think it should be all that different to have the same ability added to an RV, But I would start by contacting someone who installs and services the home units. They will be more familiar with this type of control and its installation.
And remember , you will need a shut off or by-pass to allow you to disconnect and travel or store the unit. Those aren't normally concerns for the home units.
Edit add on; For the dog concern, there are security systems which will also monitor temp, security, fire, as well as sensors for power, they will require an added internet connection for the motorhome and then would notify your phone. I have seen them discussed in here, but do not remember the name of the systems.
